Thank you. I wasn’t aware of that thread. BTW: my problem with the workflow is solved (user handling). I entered “dvn [my search]” and pressed return immediately. Then I got this error. I should have waited after entering “dvn [my search]” for the result list to fill before pressing any key at all. So everything is fine and the workflow is working flawlessly on my DEVONthink databases.
