Aliases problem
Hello everyone,
I’m using DevonThink 3 to organize my organic chemistry notes.
I like the WikiLink and Aliases function, especially after I can customize the Aliases separator.
However, I encountered some weird problems with the Aliases.
Background:
I’m using “|” (not the letter i or L) as the aliases separator.
I have a file: 2560 HEXEN-2-AL
The file has aliases: trans-2-hexenal|HEXEN-2-AL|(E)-2-Hexen-1-al|2-Hexenal|Hex-2-enal|Hex-2-en-1-al|Hexylenic aldehyde|Leaf aldehyde
What happened:
When I type any of those aliases in other files, the wiki link can be created automatically.
However, when I type or copy and paste “(E)-2-Hexen-1-al” in another file, the WikiLink doesn’t work.
Unless I type “[[(E)-2-Hexen-1-al]]”, which will automatically link to the “2560 HEXEN-2-AL” file.
Could anyone explain to me why it behaves this way?
Thank you!
Development would have to comment any technological aspects but why are you using the pipe as the separator instead of the default semicolon?
Hi Bluefrog,
Originally, I used “;” as the separator, but it doesn’t work in the situation mentioned above, so I tried “|”.
But the problem is still there.
So there is no special reason for using “|” as the separator.
Thanks
A screenshot of your WikiLinks settings would be useful.
Here is it.
Thanks
What kind of document did you edit?
I am seeing no issue with using the pipe or the default semicolon as a separator and WikiLinks in a rich text document…
It is a markdown file.
The problem I have is only with the (E)-2-Hexen-1-al. All other synonyms are okay
[[(E)-2-Hexen-1-al]] will work but (E)-2-Hexen-1-al does not.
Currently Wiki linking based on names & aliases expects a character or number at the beginning of a name or alias, this seems to be the case for the other aliases.
Okay. That makes sense. Is there a setting to enable detecting “(” at the beginning of a name? Or this will cause more problems?
No, the only possibility is to use [[…]]
Okay, thanks. I will start using [[…]] for any synonyms start with “(…)”.
