As questions about how to use create location arise quite often I’ve put together a description and a handler. Use the handler as is, take what you need from it or simply ignore it.
How “create location” works
If a group exists at a given location
create locationgets it.
It can’t be used to create a new group with the same name as an existing group at a given location. If you want that usecreate record withinstead. -
If a group not exists at a given location
create locationcreates it.
All intermediate groups are created, i.e. if a group at/Group Aexists and you usecreate location "/Group A/Group B/Group C/Group D"then Group B, Group C and Group D are created. -
create locationtakes an absolute path, i.e. always start at the root. -
create locationdefaults to the current database.
If you want a specific database appendin database "My database". -
If the provided location contains a slash
/it may be necessary to escape it.
It’s necessary if you usename of. It’s not necessary to escapelocation of.
If you manually provide a group name, e.g.Test/1, escape it directly:Test\\/1. -
create location (location of theGroup) & "Test"creates a sibling oftheGroup, i.e. they are on the same level. If you want a child oftheGroupusecreate location (location of theGroup) & (name of theGroup) & "/" & "Test".
Everything below refers to the handler. It is not create location's default behaviour.
How the handler works
This handler takes 3 parameters, from left to right:
the name of the group you want to create/get
the location (without the name)
If the provided location is an empty string""then the database’s incoming group is used. -
the name of the database
If the provided name of the database is an empty string""then the global inbox is used.
Captures
Providing no location:
Providing a non existing location:
Providing an existing location:
Providing a group reference instead of a location:
The option shown in the last capture wasn’t mentioned before as it might be confusing. It can be used if you already have a group reference and don’t want to check whether a subgroup with a given name exists or not.
-- Create location
set theGroup to my createLocation("Test", "", "") -- name (string), location (string) or group (record), database name (string)
return
on createLocation(theName, theLocationOrGroup, theDatabaseName) -- string, string or record, string
if theName = "" then error "Please provide a name."
if theDatabaseName = "inbox" or theDatabaseName = "" then
set theDatabase to inbox
else
set theDatabase to database theDatabaseName
set theClass to class of theLocationOrGroup
if theClass = text then
if theLocationOrGroup ≠ "" then
set theLocation to theLocationOrGroup
else
if theDatabase = inbox then
set theLocation to ""
else
set theIncomingGroup_Name to (name of (incoming group of theDatabase))
if theIncomingGroup_Name contains "/" then
set theIncomingGroup_Name to my escapeSlash(theIncomingGroup_Name)
set theLocation to theIncomingGroup_Name
else if theClass = parent then
set theLocationOrGroup_Name to name of theLocationOrGroup
if theLocationOrGroup_Name contains "/" then
set theLocationOrGroup_Name to my escapeSlash(theLocationOrGroup_Name)
set theLocation to (location of theLocationOrGroup) & theLocationOrGroup_Name
set theDatabase to database of theLocationOrGroup
if theName contains "/" then
set theName to my escapeSlash(theName)
set theGroup to (create location theLocation & "/" & theName in theDatabase)
activate
display alert "Error: Handler \"createLocation\"" message error_message as warning
error number -128
end createLocation
on escapeSlash(theText)
set AppleScript's text item delimiters to "/"
set theTextItems to every text item of theText
set AppleScript's text item delimiters to "\\/"
set theText_escaped to theTextItems as string
return theText_escaped
end escapeSlash
