I’ve tried to refine the “Create new quotes from selection” macro that @Kourosh presents in his book, by doing away with the UI scripting and trying to gather all quotes in a single document.
I’ve used a number of ideas from this forum, of course, and this is still a work in progress. I stole the idea to use a markdown section as a text delimiter from one of the “Backlinks” script that appeared on the forum. I’m sorry if I haven’t written down were I took my sources from …
My current script is run from a KM macro.
It creates a note in a “quotes” group in the current database.
- The name of the note can be personalised. I use “Citation -Document Alias” as a name, if the alias is defined. If not, “Citation - Document Name”.
- The quote is the selected text inside the document. If nothing is selected, an error message is generated
- The “## Reference” is a link back to the original document.
- Additional quotes will be append to the main body of the note, just before the “## Reference” section
I still have a few questions I couldn’t find answers to:
- how do I specify a database by name or uuid for the note location?
create location "/quotes" in database whose name is "memex"
throws a syntax error. - how do I get the first alias? Aliases are NOT a list, but a string delimited by comas OR semi-colons, so I can’t just say
set theAlias to the first item of (aliases of theRecord)
; this just gives me the first letter of the alias.
If this is of interest to anyone, here’s the script:
use scripting additions
-- get information
set referenceSection to "## Reference"
set theRecord to (content record of think window 1)
set theAliases to (aliases of theRecord)
-- aliases are empty, use name instead
if theAliases = "" then
set theAliases to theName
set theRecordLink to "[" & theName & ", " & theAliases & "](" & (reference URL of theRecord) & ")"
set theQuote to "> " & (selected text of think window 1) & return
on error errMsg number errNum
display alert (localized string "the Quote can't be empty") & return & errMsg
return
set theQuoteName to "Citations -" & theAliases
-- create or append quote
activate
set theQuoteGroup to create location "/quotes"
if not (exists child theQuoteName of theQuoteGroup) then -- Create the document from scratch
set theQuoteText to "# Citations - " & theAliases & return & return & theQuote & return & "## Reference" & return & theRecordLink
set theQuoteRecord to create record with {name:theQuoteName, type:markdown, content:theQuoteText, tags:quote} in theQuoteGroup
else -- Record already exists, just append the new quote
set theQuoteRecord to child theQuoteName in theQuoteGroup
set theText to plain text of theQuoteRecord
-- split at Reference section
set oldDelims to AppleScript's text item delimiters
set AppleScript's text item delimiters to referenceSection
set delimitedList to every text item of theText
set AppleScript's text item delimiters to oldDelims
on error
set theExistingQuote to item 1 of delimitedList
set theExistingReference to item 2 of delimitedList
set theQuoteText to theExistingQuote & theQuote & return & referenceSection & theExistingReference
set plain text of theQuoteRecord to theQuoteText
open tab for record theQuoteRecord
display alert (localized string "An error occured when adding the document.") & space & errMsg
