I have not much disk space left on my iPad. Therefore I want to reduce the amount of storage used for DTTG4 by setting the “Retain” slider (In the Synchronisation section) from “All items” to “500”:
Here the storage amount DTTG4 used before I changed the Retain value:
And here the storage amount DTTG4 used after I changed the Retain value:
Clearly no disk space freed up.
What is going wrong here?
Many thanks for pointers!
Thanks for chiming in!
Interesting. This raises for me the question: What does purging do? I thought it means the document file itself is removed. I have at least as many PDFs as MDs, so removing the PDF files should do quite a bit.
True, but 5GB is a lot of storage. Ikd say a significant part if this are documents files.
Good hint! So I better switch them off. Where in DTTG do I disable thumbnails and Spotlight metadata?
Purging removes the contents of a file, leaving its metadata behind.
- Disable Spotlight via Settings > Sharing & Spotlight.
- Disable thumbnails globally by going into a database, tapping the View Options bottom toolbar button, and unchecking View > Thumbnails.
It depends on what kind of PDFs they are. Do they contain a lot of images? If they’re mainly text, I wouldn’t expect much of a difference.
DT indexes the text content of your files for searching. So even if the files are purged, the text remains in the search index.
