Let’s say you have a group, called “Tags”, in which you’ve created a bunch of topical folders. You have a habit of replicating records within these folders as a form of tagging.
This works well within DEVONthink, but it doesn’t help at the Finder, which doesn’t know anything about DTP’s folder-based tagging approach.
To bridge this gap, I’ve written a Smart Groups script which will auto-tag any records which occur within sub-groups of your Tags group. For example, say you had this hierarchy:
Tags
Later, you use DTP’s Classify feature to replicate a web clipping into both of these groups. Wouldn’t it be nice if the Python records had a “&python” tag automatically inserted into their comment field, so that you could use this information when doing a Spotlight search?
The attached script works by associating it with the parent “Tags” group. Whenever you click on the group, it runs the script and synchronizing your tagged records. Anything in Python gets tagged “&python” – in addition to whatever other tags it may have. Additionally, if you move a record from Python to Emacs, the old &python tag will be removed and a new &emacs tag put in its place.
This scheme lets you do comment-based tagging using just drag-and-drop and replication, with a script trigger at the end to assign your group names as tags to their child records.
Phew… maybe that didn’t make much sense at all. It’s really a lot simpler than it sounded! If you have questions, I’ll be happy to answer them.
John
on triggered(theRecord)
set thisPath to (location of theRecord & name of theRecord & "/")
repeat with theTag in children of theRecord
set tagName to name of theTag
repeat with theRecord in children of theTag
set recordComment to comment of theRecord
set recordTags to words of recordComment
if tagName is not in recordTags then
copy tagName to the end of recordTags
set finalTags to {}
repeat with childTag in recordTags
if (get record at (thisPath & childTag & "/" & name of theRecord)) ¬
is not missing value then
copy childTag to the end of finalTags
set newComment to ""
repeat with childTag in finalTags
if newComment is "" then
set newComment to "&" & childTag
else
set newComment to newComment & " &" & childTag
if newComment is not recordComment then
set comment of theRecord to newComment
display alert "DEVONthink Pro" message error_message
on error number error_number
if error_number is -1708 then display dialog error_message buttons {"OK"} default button 1
end triggered
Here is a slightly better version, which shows a progress bar so you can see what’s going on.
Please note that this script clobber any non-tag parts of your comment fields! I haven’t yet coded a way to completely strip all tags, then append the final set at the end.
John
on joinList(delimiter, someList)
set prevTIDs to AppleScript's text item delimiters
set AppleScript's text item delimiters to delimiter
set output to "" & someList
set AppleScript's text item delimiters to prevTIDs
return output
end joinList
on splitText(delimiter, someText)
set output to text items of someText
return output
end splitText
set tid to AppleScript's text item delimiters
set AppleScript's text item delimiters to space
show progress indicator ¬
"Assigning tags" cancel button true ¬
steps (count of children of theRecord)
step progress indicator tagName
set tagName to ("&" & tagName)
set recordTags to {} & text items of recordComment
set finalText to {}
set finalTags to {}
set isText to true
if length of childTag is greater than 2 then
if texts 1 thru 1 of childTag is "&" then
set childTag to texts 2 thru -1 of childTag
set recordName to my splitText("/", name of theRecord)
set recordName to my joinList("\\/", recordName)
if exists record at (thisPath & childTag & "/" & recordName) then
set isText to false
if isText is true then
copy childTag to the end of finalText
else
repeat with childText in finalText
if length of newComment is 0 then
set newComment to childText
else
set newComment to newComment & " " & childText
else
if newComment is not equal to recordComment then
set AppleScript's text item delimiters to tid
hide progress indicator
end triggered
Hello there, I’m a Beginner with DT and still evaluating if DT iss the right tool for what i am up to.
The smart “tags” group might be excatly what i am loking for, to finally tip the scale in Favor for DT.
Just to make sure i got it right: Every image, document or other item I put into a group is assigned the groups name as a “Tag” (i.e. as information in the “comment” field, as visible in the “Information”-dialouge).
Now for my Question: Hw do i integrate the above Script into DT correctly ?
I guessed its not by just putting an .scpt file into the DT Script folder (for the Script seems to be triggert everytime files are moved between folders).
Thanks in Advance for your efforts, and time
You need to turn your “Tags” umbrella group (which contains all of the various tags as subgroups) into a “Smart Group”. This is done by opening the inspector for the group, and then associating the script that I posted with it. Then, whenever you click on the group’s name, it will trigger the script.
John
Thanks a lot for the fast Reply, works fabolously
