Is there a fast way to record an audio note with DTTG and save it in the global inbox?
I love to record ideas while driving, unfortunately it’s quite tricky with DTTG because of the many steps needed: [+] button on the main screen, then “Media”, then “Audio note”, then the record button, finally “Use” (sorry for the possibly wrong translation, my DTTG is in french), “End”… and I have to do it again from scratch for the next idea I want to record.
I tried that already, it’s a viable alternative but it’s not that practical when I suddenly have 5-10 different notes to “dictate” (means 5-10 different files or records)…
It’s always very frustrating to think that a good old Dictaphone would be much easier and more effective
Here is an iOS Shortcut that will prompt for voice recorded input and append it to a single note in DEVONthink To Go that might help. It also reads back what Siri thinks you said so you will know immediately how accurate (or not) the text will be in the note.
You will need to enable ‘untrusted shortcuts’ to import this. On import it will ask for the UUID of the note you want to append too and has a comment on how to get that UUID.
You can activate it from the homescreen widgets, Shortcuts app or Siri by saying ‘Voice Record’ (you can rename the shortcut as desired).
Let me know of issues or questions. I thought about asking for a note name, searching and grabbing the UUID but the search could return a bunch of results and I wouldn’t know which one to use so asking the user for the UUID seems to be the safest.
Your shortcut seems to be exactly what I need, fantastic!
… but I’m having an issue to install it
Because I’m using an “old” iPhone 6 with iOS 12 (too old to upgrade to iOS 13), I’m getting a message that your shortcut was made for a newer version of the app Shortcut.
I do not have access to a device running iOS 12 and there are some minor differences that I unfortunately don’t remember now…
In case someone has iOS 12 or remembers enough to ‘downgrade’ an iOS 13 shortcut, I am attaching an image of the shortcut source. I am using FIg so hopefully the image attachment works.
The first text field should have the UUID from a note in your databases as mentioned in my earlier post. iOS12 won’t have the install-time prompt feature.
