I love the formatted note which is captured by DTPro
- how to remove images after the notes are captured ,besides manually deletion
- capture as formatted note but without images
Neither of these of possible as this time.
May I ask why you’d want these options?
Thank you for quick response.
I love how a formatted note looks, readability is awesome with it .
The idea to remove the images from the note was to reduce the note size which often is >500 KB due to 3-4 images generally on a good article.
You’re welcome and that is true. A formatted note can quickly become large with the embedded image data.
Development would have to assess the request to capture a formatted note without images.
Pick a file, duplicate it, and run this code in Script Editor…
repeat with thisRecord in (selected records)
do shell script "sed -i '' 's_<img .*\\\">__g' " & quoted form of (path of thisRecord as string)
Does that work as expected?
This works absolutely fine. Thank you !!
This would be great too
You’re welcome.
Here’s a slightly error-trapped version…
if (type of thisRecord) is formatted note then
update thumbnail of thisRecord
A slightly safer RE would be
<img[^>]+>
Using a non-greedy expression that doesn’t gobble up more than absolutely necessary.
Imagine you had a img and an a element in the same line/paragraph – I think your expression would eat the a element, too.
Indeed.
's_<img[^>]*>__g' works.
