Hi - I’ve been using DT happily since 2010 - initially for my MSc, then as a file repository for a legal practice.
I would like to do the following:
Send file to the global inbox (manually), then:
DT automatically searches doc for given text strings, then
DT puts an alarm on my desktop.
I knew a teeny bit of AppleScript years ago, and have the Sal Seghoian bible, but haven’t got a clue where to start…
Thanks for the very speedy reply. Forgive me if I’m being sloppy in my choice of terms for the question:
Alarm - Should have said Notification - banner that pops out at the right hand side of my screen. Devonthink 3 sent me one a couple of days ago about how to generate a new database template.
Text string - I receive Court Case Listings as email attachments several times daily. I want to automate the process of searching them for cases in which we are instructed using either the client’s surname or the alphanumeric case reference. Obviously the list of case names / references will need updating semi-daily.
Depends how I do it - if I update weekly for what “SHOULD” be called into court the next week, then 10-20.
If I’m checking for nasty surprises on any of the cases running at any given time, then more like 100.
The UK criminal court system is on its knees, and all sorts of unexpected things can and do happen.
A smart rule for 10 to 20 strings should be ok. More than that, and it’ll become tedious.
One possibility might be to put the strings (aka case number, client names) into a separate file. A script (possibly run by the smart rule) can read this file and check the incoming record against the strings it finds there.
That’s conveniently vague From your first post, you’re sending a “file” to the global inbox. What’s the format of this file? If it’s a PDF, does it contain a text layer or do you have to do OCR on it to make it searchable?
Nothing that fiddly - the attachments are htm files. I’m trying to keep the thread out of the weeds and just making it tricker for you to help! Argh.
Not relevant to this thread, but running OCR on unsearchable pdfs and then pulling textual rabbits out of hats was one of my favourite party tricks for years. Most pdfs I deal with now are pdf&text…
Here’s a JavaScript script that can be used in a smart rule or stand alone on selected HTML files:
const curApp = Application.currentApplication();
curApp.includeStandardAdditions = true;
/* UUID of the text record containing names and case nos, one on each line */
const caseFileUUID = 'E69CC3A3-48F6-4575-B95D-327B1C8BBB2F';
/* Build an array of names and numbers from this record */
const caseNameList = app.getRecordWithUuid(caseFileUUID).plainText().split('\n');
// Regular expression to match the case number and name entries in the raw HTML data */
const RE = /<td valign="top" width="10%">(.*?)<\/td><td valign="top" width="50%">(.*?)<\/td>/g;
/* Use `Set`s for the found case nos and names because they automatically store each value only once */
const caseNos = new Set();
const names = new Set();
/* Loop over the records matched by the smart rule, weeding out all that are not HTML */
records.filter(r => r.type() === "html").forEach(r => {
/* Get the raw HTML from the current record */
const txt = r.source();
/* Find all matches in the HTML and add them to `caseNos` and `names` respectively */
const matches = txt.matchAll(RE);
[...matches].forEach(m => {
caseNos.add(m[1]);
names.add(m[2].replace(',','')); /* remove comma from name */
/* caseNos and names now contain all case numbers and names only once, bar casing.
put all names and numbers matching one entry in the case name list into `foundList`
const foundList = caseNameList.filter(code => caseNos.has(code) || names.has(code));
if (foundList.length > 0) {
curApp.displayNotification(`${foundList.join("\n")}`, {withTitle: `Matches found in ${r.name()}`});
const app = Application.currentApplication();
if (app.name() !== "DEVONthink 3") {
performsmartrule(Application("DEVONthink 3").selectedRecords());
You have to adjust the UUID at the top of the script to refer to a simple text file containing one name/case number per line.
Shortcomings
There seems to be some variability as to the casing of names: Sometimes last names are all uppercase, sometimes only the first letter is uppercase. That might cause problems if the casing in your name list is different from the court ones.
The notification only shows the first four matches. You must click on the little triangle on the upper right of the popup to expand the list. If that’s a problem, the matches could be send by e-mail or something …
Thank you very much indeed! You’re a star. JS and regexes are way beyond me (I speak 4 human languages, but programming is a different matter)
What you’ve come up with is workable for sure - the hardest bit will be adjusting the UUID each time I update the list of case names/numbers. And that’s not hard
A couple of questions:
why are the names case sensitive?
if the script is triggered by a smart rule which is looking for .htm files, what is line 18 for? " /* Loop over the records matched by the smart rule, weeding out all that are not HTML */"
I can easily extract the quotation marks, but this is what my (minimal effort) case list looks like with one reference per line:
“SMITH John” 01VV9876543
“BAR Foo” 01AA1234567
etc
Is that going to work? I’m not concerned if I get double hits - i.e. if both the above examples are in a given attachment I get 4 hits not two.
Because that’s how they arrive. It’s the court that writes “Foo Bar” once and “FOO Bar” the next time. Someone has to either lower or upper case everything somewhere if the names should be case-insensitive.
might help, but then the names will be all lower case in the notification.
As I said: The script can run stand-alone, run for example from Script Editor or the command line with osascript and working on the currently selected records. The filter call is just a safe guard for this case.
No (I sent you a sample by PM, by the way)
SMITH John
01VV9876543
BAR Foo
01AA1234567
If the name-code pairs are fixed (i.e. if you’re not interested in cases with “Bar Foo” other than 01AA1234567), then the code could be simplified.
You will not get double hits. If “Foo” is contained twice in the HTML, it will be only once in the names set used in the script (that’s why I used a set and not an array).
