Hi,
It is really hard to add tags when the word used in the tag has other endings - it just keeps reverting to the longer form. As you can see in the example below the tag “research” keeps getting changed into “researcher”.
Is there a way to prevent this?
Many thanks
The image is unfortunately tiny. Could you please post (or send us) a larger screen recording? Thank you!
Ooops sorry - here you go
As you can see the tag keeps jumping to the next longest tag. I am trying to use the tag Research and not Researcher in this case. Even if I select the tag from the drop down list it reverts to “Researcher”
I’m unable to reproduce this so far.
