If I select, say, 10 documents, then right click and choose Convert > to Paginated PDF, I would like the initially-selected (non-PDF) documents to go to trash after the PDFs of same are produced.
Is a script necessary to pull this off, or am I perhaps missing the obvious ; )
Here is a simple teaching edition version that accomplishes what you’re asking…
repeat with thisFile in (selected records)
set recDB to (database of thisFile) -- In case you're acting on smart groups or search results
set recKind to (kind of thisFile as string) -- A localized value but this is safe since it's just used for the error message, if needed
set newRecord to convert record thisFile to PDF document -- Convert the file to a paginated PDF in place
if (newrecord ≠missing value) then -- Check to see if the record was made
move record thisFile to trash group of recDB -- If so, move the original to the Trash
else
display alert "Can't convert " & recKind & " files into PDFs." -- Warn and continue…
This code would be usable on a selection in a group or a smart group - global or local.
