I just installed the latest update, and some bad things started to happen, which I have been able to reproduce. BTW - I’m running OS X Yosemite 10.10.1 on a Mac mini (Late 2102) with a 2.6 GHz i7 CPU, 8 GB of RAM, and a 1T Fusion drive.
I created a large text document, using (Scripts)->Export->Listing…, then imported it into DEVONthink Pro Office, although I could probably have used any file (it was 544 KB in size).
I then created a new empty new Rich Text inside of DTPO.
— Just to help you with my terminology, I call anything I create and edit inside of DTPO a “page”, to distinguish it from a file external to the application that was created and modified with other applications, such as TextEdit.
- I copied all the content of the text page, and pasted it into the Rich Text page. Everything appeared as expected, in the text style I usually use.
Then the fun began.
I tried searching for a string that I knew was there, and the search dialog box could not find it.
I edited the page and saved it - still nothing odd.
I then selected (in the list view) a different page to look at, and came back again - lo and behold, although the list still showed a large size, the text I pasted into the view/edit pane was completely blank. Just to be sure, I exported it as an RTF file, and looked at it with a text editor - every character was replaced with a slash:
\f0\b0\fs28 \cf0
[I didn’t count them, but I would guess that there were at least 20,000 slashes ]
The Verify & Repair tool couldn’t find anything wrong.
I quit the application, then opened it again - all my data was intact (except for the one blank page), and I tried it all again - copying text to a new Rich Text page, and doing the same thing. It behaved exactly the same way as before.
I just tried it again, and discovered that although the status bar shows:
14651 paragraphs, 180754 words, 544152 characters
and nothing appears to be missing in the view/edit window,
the saved document shows a size of only 28.8 KB in the list view and the Info window. I recall that the status bar accurately showed the number of characters when I deleted text.
I’ll first download a fresh copy of the application and install it again. If that doesn’t work, I will try to reinstall the previous version of the software and work from a backup database I exported last night. That should isolate the problem to a specific version - if need be, I can go back several versions (I save the application bundle to a zip archive whenever I update).
In the meantime, please look into the problem (DEVONtechnologies folks and users - if you have time) and see what I’m missing.
Thank you,
Ed
