Is there a way to get the Property List Editor without installing 2.4GB of software?
I’m a noob: will something like SubEthaEdit work just as well?
thanks!
thanks!
One alternative might be PlistEdit Pro:
http://www.versiontracker.com/dyn/moreinfo/macosx/22659
Or just use TextEdit, SubEthaEdit, TextWrangler etc. and save the XML files using UTF-8 encoding and the extension “.plist”. The disadvantage of using a text editor is of course that it’s quite easy to create syntax errors.
To open the included XML plugins, open the DEVONagent.app package and have a look at the Plugins folder and its .plist files.
