Question regarding results of OCR from these two separate approaches.
I have found by searching (I believe I am correct) that DT uses version 11 of the Abbyy engine.
I have been using the standalone version, Abbyy FineReader Pro, version 12, for some time, as in the past it produced smaller files and seemed to work better in general. I use a ScanSnap, Hazel, temporary Finder folders, and a script to make it work, but it works.
Now, the standalone version is not compatible with Big Sur, and there is no information I can find regarding if or when it will be compatible. So my questions are:
- Does the packaged version in DT produce nearly the same results as the standalone version?
- Will another standalone OCR software program work? I don’t mind spending reasonable money; I use the OCR function every day, and its worth it to not waste time.
- Just to confirm, I am assuming intrinsic OCR in DT works in Big Sur, for those who have upgraded.
Thank you!
