Here’s a script to convert the currently visible document view (e.g. a bookmark, a web archive, a rich text etc.) to a PDF document which is stored in the same location as the original document:
-- Capture PDF to Current Group
-- Created by Christian Grunenberg on Fri Nov 10 2006.
-- Copyright (c) 2006-2008. All rights reserved.
if not (exists think window 1) or not (exists content record of think window 1) then error "No window/document is open."
set theWindow to think window 1
set theURL to URL of theWindow
set theName to name of theWindow
set thePDF to paginated PDF of theWindow
if exists current group then
set theRecord to create record with {name:theName, type:picture, URL:theURL} in current group
else
set data of theRecord to thePDF
Just save it in the folder ~/Library/Application Support/DEVONthink Pro and it will be accessible via the Scripts menu.
