I’ve been wondering about how to best change links to a note. Here’s the scenario. I have several markdown files, variously named such as “Guide”, “Honor Guide”, “Currents Guide”,… all generally about the same thing. Each one of them has links to them from various other notes in my database.
I’d like to consolidate the notes (Guide, Honor Guide, and Currents Guide) into a single markdown file and discard the previous notes. Is there a smooth path to doing so? I can do this manually for a small number of linked files, but not if it gets into the dozens.
One thought I had was to create a central note called “Guide” for instance and then add the names of the others as aliases to this central note. But then I lose any item links. Any thoughts?
That sounds like it might be it? I’m not adept at creating scripts, so I’d have to do some studying there. If I understand it right - the script would do all of these steps?
Completely different, quick & dirty approach: transclude them all into a single Markdown file, Export or Convert (doesn’t much matter which) that file to RTF, and re-import to Markdown; then delete or archive the original files. Would that do what you need?
It wouldn’t. Ignore me; I was losing sight of the original question. You’d need to perform some kind of batch search & replace for the IDs of the original MD files, swapping in the ID of the new consolidated file – which is pretty much what your scripting solution was proposing in the first place.
@NickLowe I appreciate the suggestion, but you’re right that it would likely need some sort of batch search and replace. I’m going to see what I can come up with
I realized that I might want to do something similar, so I just wrote a script that redirects references to selected markdown documents to a single master document. Warning: primitive script, with barely any error catching, is not tested at all.
-- NOT TESTED! You MUST test this script before applying it to your production documents.
-- What this script does:
-- 1. Redirect all incoming references of selected items to a master item.
-- 2. Update aliases of master item to include names and aliases of selected items, without duplicate detection.
-- 3. This script does not actually make any change to the selected items.
property masterItemLink : "insert-item-link-of-master-document" -- manual input before running script
if (get record with uuid masterItemLink) is missing value then return
display dialog "This is an experimental script. Do you really want to continue?" buttons {"Continue", "Cancel"} default button "Cancel" cancel button "Cancel"
set theSelection to selected records
if theSelection is {} then return
my UpdateItemLinkInReferences(theSelection)
my UpdateAliasOfMaster(theSelection)
-- open tab for record (get record with uuid masterItemLink) -- optionally, open the master item automatically for checking the results
on UpdateItemLinkInReferences(theRecords)
set someDocNotMarkdown to false
set referenceList to my FindAllIncomingReferences(theRecords)
set replaceItemLinks to my ListItemLinks(theRecords)
repeat with theRecord in referenceList
if (type of theRecord) is markdown then
set theText to plain text of theRecord
repeat with anItemLink in replaceItemLinks
set theText to my ReplaceText(theText, anItemLink, masterItemLink)
set plain text of theRecord to theText
else
set someDocNotMarkdown to true
if (someDocNotMarkdown is true) then display dialog "Item links may not be replaced in documents that are not markdown."
end UpdateItemLinkInReferences
on UpdateAliasOfMaster(theSelection)
set masterRecord to get record with uuid masterItemLink
set theAliases to (aliases of masterRecord)
set addAliases to (aliases of theRecord)
if addAliases is not "" then
set theAliases to theAliases & "," & (name of theRecord) & "," & addAliases
else
set (aliases of masterRecord) to theAliases
end UpdateAliasOfMaster
on FindAllIncomingReferences(theRecords)
set aList to {}
set theReferences to (incoming references of theRecord)
set aList to aList & theReferences
return aList
end FindAllIncomingReferences
on ListItemLinks(theRecords)
set urlList to {}
set theItemLink to "x-devonthink-item://" & (uuid of theRecord)
if (theItemLink is not masterItemLink) then set urlList to urlList & theItemLink
return urlList
end ListItemLinks
on ReplaceText(theText, searchStr, replaceStr)
local prevTID
set prevTID to AppleScript's text item delimiters
set AppleScript's text item delimiters to searchStr
set theItemList to text items of theText
set AppleScript's text item delimiters to replaceStr
set theText to theItemList as string
set AppleScript's text item delimiters to prevTID
return theText
end ReplaceText
Hi @meowky Thank you for the attempt. I couldn’t get it to work. I replaced “insert-item-link-of-master-document” and it came up with some process, but there were no changes to the documents.
