Thanks! That worked. Someone at DEVONthink might want to change that string in the instructions. They read:
Send screenshots directly to your inbox
If you make screenshots and find yourself dragging them to DEVONthink Pro or ProOffice every time, here’s a shortcut for you: You can change the Finder’s location for screenshots to any folder you like. Change this to the Inbox folder and the picture is imported immediately or at least as soon as DEVONthink Pro (Office) is being opened. Follow the linked description and set the location for new screenshots to "~/Library/Application Support/DEVONthink Pro 2/Inbox/” (without the quotes). Done.
You missed the quotes. What korm suggested is fine (escaping the spaces) but what you posted clearly shows the double quotes that would have worked in the Terminal command.
The ~ (tilde) character doesn’t expand inside quotes but the $HOME variable does so this pathname will work with the double-quotes that “escape” the spaces:
"$HOME/Library/Application Support/DEVONthink Pro 2/Inbox/"
Actually, as BLUEFROG said, this works: "~/Library/Application Support/DEVONthink Pro 2/Inbox/” using the quotes. All I’m saying is, it still reads wrong in the instructions because it tells you NOT to use the quotes. I just looked and that still hasn’t changed.
Can you direct them where to find the error? I suspect that is what you intended to do earlier, but the link you posted doesn’t have anything to do with DEVONthink.
The link that was posted in my quote was part of the instructions for changing the location.
Go to the Devonthink ‘Tips and Tutorials’ page; devontechnologies.com/suppor … rials.html
then scroll through the tips until you reach the one about changing the screenshot location.
