For my note taking, it would be excellent if I could take advantage of placeholder text when constructing links between documents.
For example, in the YAML header for a document, I might add this line:
articlePageLink: x-devonthink-item://02E67379-557A-46C0-BF4C-A42A3D51828D?page=
Notice that after the item link, I added ?page=. Now in the body of my document, I can type the placeholder %articlePageLink + the number of the page I’m citing to easily construct a URL for that page. But it doesn’t work like a link - it’s just text. I’ve tried incorporating these placeholders into a couple different markdown syntax, but as far as I can tell, no syntax is capable of creating clickable links using the placeholder text.
Below I’m pasting the markdown source code and a screenshot of the rendered text for a note where I attempted to use this placeholder trick.
# Annotations for [[Beller - Paying Attention The commodification of the sensorium (2007)]]
Lorem ipsum.
> Lorem ipsum.
[Page 5]
Lorem ipsum.
> Lorem ipsum
[Page 7]
> Lorem ipsum.
[Page 8]
[test page]
<[%articlePageLink]6>
<x-devonthink-item://02E67379-557A-46C0-BF4C-A42A3D51828D?page=6>
[Page 5]: x-devonthink-item://02E67379-557A-46C0-BF4C-A42A3D51828D?page=4
[Page 7]: x-devonthink-item://02E67379-557A-46C0-BF4C-A42A3D51828D?page=6
[Page 8]: x-devonthink-item://02E67379-557A-46C0-BF4C-A42A3D51828D?page=7
[test page]: [%articlePageLink]6
In the screenshot you can see at the bottom of the page the text of the DEVONthink item link I used is rendered in an identical way. The only differences is that the line using placeholder text doesn’t create a hyperlink.
And the line above it (“test page”), isn’t really clickable, either.
