i have a problem with certain pages like some newssites an especially with reddit. Everytime i want to clip an reddit page as an pdf over the “clip to devonthink”-extension i get an blank page, or just the headline.
I tried different Browsers (Safari and FF) and the results are the same. Even if i checked the “clear version” for my pdf clipping.
I am Running the latest MacOS 12 with the usual contentblocking measures in each of the browsers like (UO and NoScript).
I have tried it just a few moments ago and it doesn´t work
I deactivated every ad- and scripblocker i was using with these browsers. The result is still some blank pages, some come with the obligatory cookiewarning and some pdfs show a few lines of the redditpage i want to clip.
Here is an example of how the pdfs look. And i tried an different Browser (Vivaldi) with no blocking at all but with the same result. But this problem seems to be tied to some specific - like reddit - sites. i clipped a few other sides as an pdf with no problem at all - even with ad and scriptblocking on.
Add a bookmark to Reddit in DEVONthink, then select it and log in. Go to the desired page – still in DEVONthink – and use Tools > Capture. How does that work for you?
Thanks for the tipp, but sadly this doesn´t work at all:
Reddit “inside” of devonthink doesn´t load new posts - i see only the first 4 on the top
I am not able to login, becaue everytime i hit the loginbutton reddit seems to be greyed out (there must be some new greyish layer ontop of the site) and there is no field to put my credentials in
I´ve run this with and without Blocking of Popups and Ads under Settings-> Web in Devonthink
Edit: My OS Version changed since the release of yesterdays MacOS update. So it is 12.7.4 and Safari 17.4.
