I request a setting that allows you to set a default new item type. Then, you can tap, or tap and hold to create that item type. You perform the opposite to get the menu.
I’d like a feature to convert items to other types. Specifically, web archives to PDF so I can mark them up.
I’d like to me to set a template for web capture. $date $title
I’d like to be able to capture directly to PDF, like for web pages.
I request that the Clip to DevonThink popup be larger so I don’t have to tap > to confirm or choose the format. And/or allow me to set a default format. I think a scrolling selector would be nice.
Initial thoughts is that clip is about twice as tedious as it needs to be.
Clip to DevonThink Body field is too small
When editing body, all other attributes below are covered by the keyboard. Keyboard needs a Done button, maybe? Only way to dismiss keyboard is to tap >. That means if I want to apply tags, flag, etc. I then need to tap back <.
