I have been experimenting with Clip to Devonthink and have run into a problem.
I am legally blind and so use huge fonts on my computer. Unfortunately this is a problem for CtDT. The window that comes up is off the edge of the screen and is also fixed in position, so I cannot move it up to be able to click on the buttons. If the window could at least be moved this would not be a problem.
I don’t know that anything can be done but I wanted to draw this to your attention.
Would you be willing to test a development build of the Clip to DEVONthink Safari extension for me, to see if it resolves your issue? It doesn’t currently appear off-screen when I test it zoomed in, but I want to be sure that I’m testing the same thing as you
