CloudKit sync problems, how to start over
I lost my encryption password and tried to start over with my CloudKit sync. Cleaned the location on the Mac and iPad, delete CloudKit sync, enter new password, get occasional errors about the encryption password, clean again, seemingly starts working again, uploading, sync shows up to date and then at some point forward starts complaining about encryption again and says it has never synced. Lather, rinse, repeat. Seems to work and update sync times and then decide later it’s never done so. Been through several rounds of this over the last few days and it is getting tiring.
To get the ball rolling:
  1. Have you updated the encryption key on all devices?
  2. Are you super-certain you’ve typed in the right key without any errors on every device?
  3. Have you tried a sync without an encryption key to see if it’s working ok?
In DEVONthink To Go, select Action (…) menu > Contact Us to start a support ticket.
