I’ve been trying to use smart groups with a modified script (given to me by Eiron a while back) that looks only to the comments field for its parameters. I am using a key word in the comments field for files I want to group within the smart group. For some reason, it will work when I first create the folder—the tagged files show up in the new smart folder—but it won’t work for any subsequent files in which I use the exact same key words in the comment field. I used to be able to close and open the folder to get them to show up, but that’s not working.
Here is the script I’m using:
tell application “DEVONthink Pro”
repeat
display dialog “Enter the words to use:” default answer “” buttons {“Cancel”, “OK”} default button 2
set theWords to the text returned of the result
if theWords is not “” then exit repeat
set theRecord to create record with {name:theWords, type:group, attached script:"~/Library/Application Support/DEVONthink Pro/Smart Group/Comments only.scpt"}
my triggered(theRecord)
display dialog error_message buttons {“OK”} default button 1
end run
on triggered(theRecord)
if type of theRecord is group then
set theString to (name of theRecord) as string
search theString comparison no case within comments operator all words replicate to theRecord with removing replicants
end triggered
Any suggestions would be appreciated!
