Compatibility between DEVONthink 4 and DEVONthink To Go 3
Congrats on the release of DT4!
Quick question – if I upgrade to DT4 on my Mac, does DTTG 3 (which I use on iPad) still work seamlessly with it?
Saw another post about a possible future DTTG update, so assuming the new features specific to DT4 aren’t yet included with DTTG (which is all good). Just want to be sure before upgrading that DT4 and DTTG 3 are still compatible and work together on all the existing version 3 features.
Thanks for any insight!
Thanks for the kudos!
Your assessment is correct: DEVONthink 4 and DEVONthink To Go 3 will sync and work together except for the newer features in Copernicus, like audit-proof databases. It would be very bad form if they didn’t work together in the way 3.x did.
