Compressing a PDF using a Smart Rule
I’ve been using the PDF Squeezer app (also available through Setapp) as I find it reduces the file size better than other methods, particularly for PDFs with giant embedded photos. I’ve automated it using a Smart Rule but before I let it go crazy on my precious records, would someone take a look and let me know if I’ve screwed it up somehow or, even better, if there’s a superior way of achieving this same result please?
It seems to work but this is unfamiliar territory and the people on this forum are always so kind and helpful. Thank you in advance.
Embedded AppleScript:
			set recPath to (path of theRecord)
			set qRecPath to quoted form of recPath
			do shell script "$HOME/bin/compress-pdf.sh " & qRecPath
end performSmartRule
compress-pdf.sh
NB pdfs is the command-line version of PDF Squeezer
#!/bin/zsh
# compress-pdf.sh
# Compress PDF using PDF Squeezer
# Check if the pdfs command is available
if ! command -v /usr/local/bin/pdfs &> /dev/null ; then
    echo "pdfs command not found. Please install PDF Squeezer package."
    exit 1
fi
# Check if a file is provided as an argument
if [[ $# -eq 0 ]]; then
    echo "Usage: $0 <PDF_FILE>"
    exit 1
fi
# Get the input file path
input="$1"
# Check if the file exists
if [[ ! -f "$input" ]]; then
    echo "File not found: $input"
    exit 1
fi
/usr/local/bin/pdfs "$input" --profile "$HOME/appconfig/PDF Squeezer/Medium.pdfscp" --replace
It is better to be more specific in searches, smart groups, and smart rules, so I suggest adding a criterion: Kind is PDF/PS. And there’s no size threshhold to filter down to PDFs that really need squeezing. Do you really need to do this often enough to create a smart rule for it?
The echo’s wont go anywhere but it’s non-fatal.
Is this installed in this location by PDF Squeezer?
Thank you as always Jim. These are terrific suggestions. I’ve added the PDF/PS criterion. The shell script is mine, but PDF Squeezer does install pdfs to /usr/local/bin/ by default. Is there a way to direct the echos back into DT?
I wouldn’t say I compress files frequently but some PDF web clips are unnecessarily large. For example, this one saves as 36mb but compresses down to 3.5mb. More significantly, I mostly work on a MacBook but have a Mac mini always running in the background with DT. By adding a tag on the MacBook, it’ll get compressed on the Mini in the background once I change the triggers. (And I don’t have to run PDF Squeezer locally - it’s a Rosetta app.)
You’re welcome :slight_smile:
The echo’s could be used in DEVONthink’s Log window but I’m not at my Mac right now so I can’t show any code.
Thank you again Jim: your patient support is the bedrock of this wonderful community.
Ugh! I am running into a sandboxing issue getting the pdfs executable to run form an App Store install.
FYI, I use PDF Squeezer all the time on most the PDFs that I capture. It’s quick and fast. When I first started with it I like you thought I would create a Smart Rule to use it automatically. I did not pursue as I thought I needed the command line interface option, but I’ve been unable to get it going and the developer hasn’t answered my questions–my only quibble with the product.
So in the meantime I learned how easy it is to select, say all the PDFs still in the Inbox, then drag/drop them into PDF Squeezer. PDF Squeezer set by default to do “Strong Compression”. But for some documents that’s too much. PDF Squeezer shows the original and “squeezed” version and for those PDFs that become “fuzzy”, I change to “Medium Compression” which normally corrects the fuzziness even on images. Once happy with the set of squeezed PDFs, I select all and save back into DEVONthink. Sometimes the reduction is orders of magnitude without significant loss in readability.
So, despite the command line option and lack of support, it’s a good product.
Thanks! Like you, I found the Medium profile to work the best. You can export the profile from PDF SqueezerSettings. I saved it as $HOME/appconfig/PDF Squeezer/Medium.pdfscp.
All the rest of this is just wrapping around the command-line command of:
Both parameters after the input filename are optional. --profile to make it use the Medium profile, --replace so it overwrites the input file with the compressed file. The latter is the equivalent of doing an Open With… PDF Squeezer in DT, then once PDF Squeezer has compressed the file, saving it.
If you’d still like to pursue a command-line automation then what is above will work and works even better and safer with Jim’s suggestions. My main stumbling block was not understanding how to get the DT record’s full path including filename (and then ensuring it was quoted).
As I’m sure you already know, you have to install the command-line pdfs from the Settings first. (I also used these automation tools to create a simple macOS Shortcut attached to a Finder Quick Action.)
Under recent versions of macOS, you may also need to give the Terminal access to the DT directory in macOS System SettingsPrivacy & SecurityFiles and Folders or Full Disk Access.
Actually, I use “Strong” probably 98% of the time for that orders of magnitude squeeze I mentioned. Most of my stuff is text. “Medium” only by exception and then only for those PDFs that have images that I find important enough to keep not-fuzzy. If i make the wrong decision and Strong squeeze something that later I can’t read, I can always go back to the original (if still available, which is likely).
My problem with the automation setup in PDF Squeezer is the “grant access” button which reports the error:
“The open file operation failed. The open file operation failed to connect to the open and save panel service”.
From that I conclude it “failed”. What to fix or repair is a mystery. Not really important to me anymore as I have the process as described above as without AI making the decisions on compression levels, I use my aging and hopefully-not-artificial brain/eyes.
That’s exactly what I’m seeing in the App Store release.
I’ve sent in a support request a couple of times with no reply. Nothing like support from you guys!
I also use the PDF Squezer. However, I do not use a shell script for the compression but the PDF Squezer Action in a workflow. I have realised that the action runs more stable than a shell script. If you are interested, I can post the workflow here, maybe it will help someone.
Yes please that would be terrific! Thank you
Here the screenshot. I did not add the settings of PDF Squeezer, there are many and you must decide what you prefer.
wishes
mr_drlove
Did you crib that AppleScript code from our documentation? :slight_smile:
It would be more helpful to post code as such – copy/pasting a screenshot is not useful.
Include code in three backticks like so
code goes here
No, but I had support from one of your colleagues (a long time ago)
Many thanks for the suggestion. If you can explain to me how I can make the code part of the PDF Squeezer (in the centre) visible so that I can copy it too. Then I’ll be happy to do it! I didn’t find the variant of working with code AND screenshot useful.
Code – image – code.
Also, you should use selected records instead of selection. And copying the selection to a new list should not be necessary – just return selected records if anything is selected.
ok, here we go.
I was not able to get it working with removing the “copying” part. Perhaps I did not understand what you mean.
Start of the workflow
on run {}
activate
set fileList to {}
if selected records ≠ {} then
repeat with thisRecord in (selected records as list)
copy (path of thisRecord) to end of fileList
return fileList
end run
Picture for the middle, see some posts below
end of the workflow
set theSelection to selected records
deconsolidate record theRecord
synchronize record theRecord
