when i convert HTML files to formatted notes, sometimes only part of the note converts. it seems like if there’s a video file in the html, it will not convert to format and will not convert past that point. so i don’t care if the video file disappears, but i do want the rest of the document to be part of the conversion. have tried with a few different documents now and it isn’t working.
Have you tried deleting the video from the HTML file before converting?
Formatted notes are static HTML-based notes, e.g. scripts or multimedia are not supported.
yes i know that, which is great - but in the past i think it’s just skipped over the multimedia file. Now, it stops converting once it reaches that part of the html file.
Could you please send me such an HTML file via email? Thank you!
