When I try to convert a PDF (with text layer) to RTF using the context menu or the main menu, nothing happens. The protocol window says
02.02.25, 11:01:22: Test > heizkostencheck	Nicht konvertiert
(not converted). This happens for every PDF I tried it with. The one referred to in the message above has about 238 KB. The documentation says that “convert” will only offer target types in which the source can be converted.
Am I doing something stupid, is the conversion from PDF to RTF generally not working, or should I look out for something peculiar in my PDF?
