On 2.4.4, converting a plaintext note to a formatted note removes line breaks. This is new behavior. Here’s the example:
Domaine: Roche aux Moines
Year: 1992
Variety: Chenin Blanc
Alcohol content: 12.5%
Grade: A
Notes: Well-integrated, minerality, like silk, nothing edgy
Date: 2018-03-07
Converting this to a formatted note results in this:
Name: Savennières Domaine: Roche aux Moines Year: 1992 Variety: Chenin Blanc Alcohol content: 12.5% Grade: A Notes: Well-integrated, minerality, like silk, nothing edgy Date: 2018-03-07
Did something change in the update that would cause this? I haven’t changed anything in the way the plaintext is generated, and previous wine notes like this converted no problem.
This issue was not addressed in this build.
Note that reporting an issue doesn’t mean it will be addressed in the next build. It means the issue has been reported to iOS Development.
This is still not fixed. I know it’s not close to a major feature, but it is one feature I do use. I have been using a workaround, but thought I’d check out any status it might have, as it’s been another 6 months.
Ha! The first word that came to my mind was from my high school German class: “Ausgezeichnet!” Every March, I would think, “Should I bother them about this again?”, and just decided not to. Amd then you eventually got around to it. Thanks very much.
Really, you all are great. I’m glad to support such a company, and I use DEVONThink every day.
