Hello there,
switching from windows, I’m missing the “Send to USB-Drive”-option in the context menue. I often need to copy single files to an USB flash drive and it would be nice if it worked something like this way: select the file and then press a keyboard shortcut or use one (or two) mouse-clicks. It’s always the same drive…
For now, I’m opening the finder and drag-n-drop the file from Devonthink to the finder. I suspect, there is a more elegant way…
Thanks for your advice!
David
