This script copies selected PDF text and a Markdown link.
Change property theDelimiter
if you want the Markdown link e.g. below the text.
-- Copy selected PDF text and Markdown Link
use AppleScript version "2.4"
use framework "AppKit"
use scripting additions
property useSuffix : true
property theDelimiter : space -- or e.g. linefeed & linefeed
if not (exists think window 1) then
error "Please open a window"
else
set theWindow to think window 1
set theRecord to content record of theWindow
if theRecord ≠missing value then
set theType to (type of theRecord) as string
if theType is in {"PDF document", "«constant ****pdf »"} then
set theSelectedText to selected text of theWindow & "" as string
on error
error "Please select some text"
set thePage to current page of theWindow
set theRefURL to reference URL of theRecord & "?page=" & thePage
if useSuffix = true then
if theName does not end with ".pdf" then set theName to theName & ".pdf"
else
set theName to name without extension of theRecord
set theMarkdownLink to "[" & theName & "](" & theRefURL & ")"
set theQuote to theSelectedText & theDelimiter & "(" & theMarkdownLink & ")"
my setClipboardToPlainText(theQuote) -- necessary in macOS Mojave
display notification "Copied"
else
error "Please open a PDF record"
else
return
on setClipboardToPlainText(theText)
set thePasteboard to current application's NSPasteboard's generalPasteboard()
thePasteboard's clearContents()
(thePasteboard's setString:theText forType:(current application's NSPasteboardTypeString))
end setClipboardToPlainText
