Crash on manual input of custom date in Smart Group context
Hello,
I would like to ask for help identifying an error. I have a custom date field with the following configuration:
  • Type: date
  • Form: date
  • Identifier: data_zapłaty
I use this field to record the invoice payment date.
I created a smart group that searches for documents without this date (condition: is less than or equal to 1/1/2021, 00:00:00). I fill in the date manually.
When entering the date, the application crashes. The crash report is attached below. I’ve never had this issue before.
I suspect the problem may be related to typing the date using the keyboard. The data_zapłaty value changes, and at the same time, the smart rule removes the file because the condition is no longer met.
Raport.pdf (48.7 KB)
Did you this happen only once or are you able to reproduce the issue?
I am able to reproduce the issue. To test this, I flagged a set of documents and created a new smart group filtering by Flagged instead. In this case, I was able to update the data_zapłaty field without any crashes. This seems to confirm that the crash only occurs when documents are being actively removed from the smart group while editing metadata.
Please choose Help > Report Bug while pressing the Option modifier key and send the result to cgrunenberg - at - devon-technologies.com - thanks!
I’ve sent it from: wojciech.olszewski-at
You may wish to delete your email … bad people and bots are said to capture exposed emails for nefarious purposes.
