Crazy suggestion: accept links in search boxes
@BLUEFROG @Stephen_C
thank you for your comments. Please give me some time to create a complete functional example combining typinator and DevonThink, and limiting myself to a few test DevonThink groups and subgroups.
I will post the complete functional model here.
At your leisure and convenience :slight_smile:
@Stephen_C @BLUEFROG
I created a typinator set for DevonThink
abbreviation = group (=folder) name
expansion = group (=folder) link
I created 2 test groups in DevonThink called bluefrog and stephen and items in the typinator DevonThink
type global typinator shortcut → type the DevonThink typinator keyword to search only the DevonThink set → type search string → when I press on enter, the expansion (link) corresponding to that group (folder) is typed.
I would like to use that Link in DevonThink search popover for move to, go to, copy to, etc
Aaaah - now I understand what you’re doing: thanks for the detailed explanation!
I haven’t tried using Typinator in effect to expand group names in DT. However, why not simply use abbreviations for the relevant group names rather than trying to use the DT links?
For example, just set xbs to expand to Bank Statements and then type Control + Cmd + G to open the go to popover, type xbs and hit return. I did try that and it works perfectly.
Edit: I have tried that and I think it would fit with your workflow. In other words, simply create a Typinator abbreviation for each relevant DT folder you want. You can then use the Typinator search to find what you need and enter it in DT, where it automatically expands.
Stephen
This script adds a record’s Reference URL to its aliases.
-- Add Reference URL to aliases
		if theRecords = {} then error "Please select some records."
			set thisRecord_ReferenceURL to reference URL of thisRecord
			set thisRecord_Aliases to aliases of thisRecord
			if thisRecord_Aliases does not contain thisRecord_ReferenceURL then
				set thisRecord_Aliases_list to my tid(thisRecord_Aliases, {", ", "; ", ",", ";"})
				set end of thisRecord_Aliases_list to thisRecord_ReferenceURL
				set thisRecord_Aliases_string to my tid(thisRecord_Aliases_list, ", ")
				set aliases of thisRecord to thisRecord_Aliases_string
		return
on tid(theInput, theDelimiter)
	set AppleScript's text item delimiters to theDelimiter
	if class of theInput = text then
		set theOutput to text items of theInput
	else if class of theInput = list then
		set theOutput to theInput as text
	return theOutput
end tid
:bowing_man:
Stephen
Thank you very much @pete31 !!
Sorry: I can’t see the script output. It is not in the clipboard and I was not asked to create a file.
Look at a recordā€˜s aliases.
The script adds selected records’ reference urls to the records’ aliases.
  • Select some records
  • Run script
Paste a record’s reference url in a popover to reveal exactly this record.
I have to read about aliases in DevonThink. I am in above my head. thank you very much
An alias is simply another way of labelling a record (including a group) in DevonThink. What @pete31 has cleverly done is to produce a script which well, as he said, adds the reference url to the aliases for the relevant records. That, in turn, allows you to address, and find, those records (including groups) by those reference URLs—which is, I think, just what you wanted to do.
Run the script on some selected records then try your workflow—trying to go to them, for example, using the reference URLs you’ve presumably added to Typinator.
So far as I’m concerned (and it’s my strictly personal view, of course) it all seems a rather long-winded way of getting around in DT. :grinning: Having read about aliases this morning I’ve just added some shorthand abbreviations, in DT, to my most popular groups and can now go to, or move something to, those groups very quickly using those abbreviations.
Stephen
Here’s a screenshot from the generic inspector for one of my DT groups which may help:
You’ll see I have a group called Temp. The alias I’ve set enables me simply to type tp to go to, or to move something to, thatt group. Maybe that helps to make things a little clearer.
Stephen
thank you.
Now I understand. Thanks very much @pete31
I developed and approach with Evernote using Typinator which worked very well and which I want to apply to DevonThink and which I think you would find interesting.
Based on suggestions by the Typinator developer Gue.
Based on your note, you do not understand my intention. Entirely my fault for not explaining correctly. The best way for me to explain my thought is if I could find a way a generating a simple clean line by line listing of all groups and subgroups which I would subsequently import into typinator. In that list, I want no documents, no tags, no links (for the moment), no strange characters, no tabs, no quotes, etc. If this was possible, I could test on my mac and post the solution here.
I tried all kinds of scripts in the forum and none give me a clean simple list. It’s very frustrating.
Oh, he’s a first class guy and really helpful.
Yes, I was worried that might be the case: sorry! :smiley:
Let’s just reduce it to a simple example. Imagine that you want to move to one of your DT groups. Presumably you would start by pressing Control + Cmd + m in DT. Are you then maybe suggesting that there could be some way of using Typinator quick search to find the group to which you wish to move and having Typinator complete the name, or alias, of the group in the Control + Cmd + m popover in DT (presumably based on having a complete list of groups, or their aliases, in Typinator)?
No need to apologise for not being clear. It’s not easy if English isn’t your first language (and, as you will have seen from many of my posts—it’s not easy even if English is your first language! :rofl: )
Stephen
Not knowing what input format would be required for Typinator, here is a simple snippet of code that returns the names of the subgroups of a selected group in a database…
	repeat with theRecord in (selected records)
		set recLoc to {location, name} of theRecord
		return name of ((parents of current database) whose (location contains (recLoc as string)))
How do I send the results to the clipboard or a file ? thank you
What kind of file?
And here’s a version utilizing the clipboard…
set od to AppleScript's text item delimiters
		set recLoc to recLoc as string
		set AppleScript's text item delimiters to linefeed
		set subGroupNames to (name of ((parents of current database) whose (location contains recLoc)))
		set the clipboard to (subGroupNames as string)
I’m sure I shouldn’t muddy the waters—and shall keep out of this after this post—but running your script returns rather a lot of blank results for me, for selected records.
I was in fact wondering if what in fact @rufus123 needed was given by amending your line return name… to return item 1 of recloc (which then provides me something like "/Diary entries/2020-2029/2021/").
Sorry for interfering!
Stephen
No interference at all.
Here’s a version that only accepts one selected group and prompts if the group is empty…
	if (count (selected records)) = 1 then
		set theRecord to (item 1 of (selected records))
		if subGroupNames ≠ {} then
		else
			display alert "This group has no subgroups."
	else
		display alert "Select one group to process."
