I am trying to use DEVONthink To Go’s “Create Item” shortcut in the iOS / ipadOS Shortcuts app, and it does not seem to be able to communicate with DTTG. The shortcut accepts three parameters, one of which is the group that the new item is supposed to be created in. When I click on this parameter in the editor, a selection dialog with a search bar pops up but displays the message “Die Kommunikation mit der App ist nicht möglich” and I can’t select / search anything.
Is this a problem with my setup or an issue with DDTG?
Great that it’s solved now.
