i would like to adapt my custom icons depending on dark/light mode
afaik icons does not support different color versions for this purpose, and all is managed directly by app.
so my first idea would be to change it with daily smart rule, there is a best way?
linked to this can i check by script the current color mode?
Thanks
I’m still on Mojave so don’t know whether that works in Catalina and above
-- Check whether macOS uses Dark Mode
-- Note: Don't know whether that works in Catalina and above
set isInDarkMode to false
do shell script "defaults read -g AppleInterfaceStyle"
set isInDarkMode to true
return isInDarkMode
I know one can find out whether a record has a thumbnail with this
-- Find out whether a record has a thumbnail
if theRecords = {} then error "Nothing selected"
set theRecord to item 1 of theRecords
thumbnail of theRecord as anything
set hasThumbnail to true
on error
set hasThumbnail to false
return
But how do you want to find out who set the thumbnail?
As far as I know it’s not possible to determine who set it (i.e. the user or DEVONthink or a file already had a thumbnail when it was imported).
If that’s true and we can’t tell who set a thumbnail then changing records that got a thumbnail would change all records with a thumnail.
Or do you use custom meta data or the like for this?
thanks pete, the icon are setted by smart rules, as visual help, related on metadata content.
my question was about a viable way, to have specific icon for light/dark mode.
i was aware of your work (very smart) but not exactly what i searching for.
with this trend of dark mode i thought that should have been a simple way to swap icons, the same way .icns adapt their size.
i’ve not experience with new apple custom icons guidelines, maybe i’m wrong, but seems to me that only inside app i can define and show custom icons depending on interface style?
i tryed to create custom pdf icons with alpha layer, to experiment with blend modes, but mac os x engine seems always to add a white background to it, only bitmap png icons seems retain tranparency.
