I’m trying to set up a search that will use my own bookmarks as the basis for the search (using the bookmarks plugin). I’ve attached a composite image of the relevant tabs from the search set parameters. (You can see the entire image when opened in its own window.) When I run this search, DA immediately crashes. Not sure what I’m doing wrong. Appreciate any help.-John
Hold the Option key and choose Help > Report Bug to start a proper Support Ticket for crashes. Thanks.
Thanks. Sent the bug report. We’ll see.
I have the same problem, so I hope for the fix as well.
My situation is, I applied the same search set to iMac and MacBook pro, but it crashes only on my MacBook.
Regards.
Again, please open a Support Ticket.
