DEVONthink Forum Post - Database Sync Issue
Hello,
I am setting up DEVONthink on a new laptop. I am having an issue with syncing one of my databases. All of the other databases have synced properly except one. The database is working normal on my other computer and mobile app. I am not sure how to to address this, and I am fearful of creating data loss with troubleshooting.
Any suggestions would be helpful. Thanks.
Did you use the forum search? It should turn up about a gazillion of suggestions. If none of these help (which I doubt), you should at least describe your problem in more detail. Nobody but you can know how you sync, for example.
Thanks for the reply.
Yes, but I will take another look.
I am using DropBox to syn databases.
I wish we could integrate the forum into DEVONthink a public database. It would make it easier to find information. It is funny to think we store help info on a weaker search platform than the product we are using. Or, maybe we can integrate a new AI Chatbot. It would reduce the time spent responding to forum questions.
Under Sync > Why isn’t sync working?
Thank you!
You’re welcome :slight_smile:
