Hi,
I know that iCloud sync mobile has been raised before here on the forum. I hadn’t yet seen anything about what I wanted to share here. If they DevonThink dev team has not seen it yet there are a few products our there that have solved this problem. The solutions are becoming more common.
The AgileBits/1Password team has implemented sync on iCloud for apps outside of the Apple Mac App Store. They’ve open-sourced their implementation here: github.com/agilebits/agilecloudsdk/
The Synium/MacFamilyTree team has also implemented an iCloud sync solution like the AgileBits solution. See: syniumsoftware.com/en/mobile … sync-share.
Both products have dataset sync needs and dataset are somewhat similar to DevonThink in terms of documents, photos, binaries, and metadata. Both solutions are not based on iCloud drive. The AgileBits implementation is based on Apples’s CloudKitJS and CloudKit Web Services, and it appears that Synium team is using a similar implementation.
I’d definitely like to see this capability come to DevonThink. I’m looking switch out of Evernote and Dropbox and consolidate on DevonThink and iCloud.
Thanks,
Jeff
