My mac, version 10.6.5.
My devonthink doesn’t want to respond. When I open it, the data bases are not uploaded. So I downloaded a new version of devonthink Pro, but still the problem is the same. I can see my data bases on the file menu of Devon but no way to open it.
Have you perhaps changed the location of your database files? In that case the paths to the databases that DEVONthink uses would be changed so that DEVONthink can no longer find them, and the command File > Open Recent doesn’t work.
If that’s the case, what happens if you choose the command File > Open Database and navigate to and select one of your databases?
Thanks for your reply. Yes I do have changed location of the database, but long time ago. And it was working.
Finally I have re-downloaded a new version of Devon Pro. It seems to work, but time to time DT close without any reason.
