must be something like this.
Perhaps DTPO should check (like some other apps) on startup that it is running from inside the Application Folder and not from somewhere else?
No problem. Coincidentally, I had another User a few weeks ago that had multiple versions installed, so I was fully aware that you can’t spawn more than one instance of the apps.
