Change the search behavior to match macOS / iOS
Currently: num > does not match the file name numbers, thus no results would have to match with num*
iOS / macOS: num > matches numbers
With markdown documents, want to see the preview and not the source code (especially when searching) but it seems to forget that I changed the view when navigating away from search and back.
This is inaccurate.
In DEVONthink, num matches numbers when using a wildcard, e.g., num*.
It also matches a substring when Partial matches while typing is enabled in the search options. This assumes an asterisk wildcard at the end of the last search term, so it is matched as a substring. When you press Return, the wildcard is removed and the last term is treated as a word.
If you’re not using that search option, you can always explicitly use the wildcard. That will obviously be preserved after hitting Return.
This is already a preference and long has been: Preferences > Files > Markdown > Markdown Display.
