Hi,
I have 2 computers that I want to sync my database. Say Folder-A. This folder is synced via icloud on DT. However, I forget to close database when I close the computer. Hence, I am afraid this may cause some issue?
I also use rclone (pcloud) to sync the same folder to pcloud? And then back to my computers. I wonder whether this will cause in terms of DT usage or not?
Thanks,
No, it won’t. Please read Help > Tutorials > Understanding Sync.
Why are you doing this in addition to using our sync engine?
Hi,
Glad to hear it will not cause any problem. I will read the documentation.
Since not all the machines I have is on macOS, I need to work on that folder also on Linux machine. Besides, cloud keeps a versioning of the files. I will give this a try, if there is no technical issue that prevents the usage.
Thanks,
