What is the difference between Devonthink 3 and Devonthink 3 Pro. I have always had Devonthink Pro Office and have used a really old Scansnap, so regularly made use of OCR. However now with Catalina the Scansnap is defunct, so I have started using an iPhone app Scanner Pro which actually does OCR for you. I get Devonthink to Index the scans.
So I don’t need OCR. I am thinking of upgrading, and not sure whether to go for the Standard or Pro edition. I can’t seem to find the information about the difference between standard and pro.
I would echo @apb123 request, would it be possible to have somewhere the list of features of the Standard edition? I know what I miss if I don’t buy the Pro version, but is not quite clear to me what I get if I buy the Standard edition.
I upgraded a few days ago and was confused about this too, particularly OCR.
I opted to only go for the standard version, and have since found that there is a menu option to OCR documents (at least PDF which are a majority of my files) and it does seem to work. It now shows the file type as PDF+Text.
