Hi,
I’m trying to create a script that will allow me to copy an email from mail.app into devonthink. I’ve copied the existing script but I am trying to modify it to do two things:
- Ask me to apply a label
- Ask me which group to put the message in.
I can get a group dialogue box to open using “display group selector,” but the messages never save in the folder I specify. Any thoughts on how I might pull this off?
Thanks for any help anyone can offer with this.
Just post the code of your script, that will simplify the debugging.
-- Import selected Mail messages to DEVONthink Pro.
-- Created by Christian Grunenberg on Mon Apr 19 2004.
-- Copyright (c) 2004-2009. All rights reserved.
-- this string is used when the message subject is empty
property pNoSubjectString : "(no subject)"
tell application "Mail"
if not (exists current database) then error "No database is in use."
if the length of theSelection is less than 1 then error "One or more messages must be selected."
repeat with theMessage in theSelection
my importMessage(theMessage)
if error_number is not -128 then display alert "Mail" message error_message as warning
set theLocation to display group selector "Destination" buttons {"Cancel", "OK"}
on importMessage(theMessage)
set theDateReceived to the date received of theMessage
set theDateSent to the date sent of theMessage
set theSender to the sender of theMessage
set theSubject to subject of theMessage
if theSubject is equal to "" then set theSubject to pNoSubjectString
set theSource to the source of theMessage
set theReadFlag to the read status of theMessage
set theRecord to create record with {name:theSubject & ".eml", type:unknown, creation date:theDateSent, modification date:theDateReceived, URL:theSender, source:(theSource as string)} in incoming group
set unread of theRecord to (not theReadFlag)
set label of theRecord to 1
end importMessage
So, this is just a modification of the script that comes with devonthink… (almost) no original work here.
I have managed to get devonthink to bring up a group selector using:
But I cannot get the messages to go into the selected folder.
Also, I was able to hard-code in the label:
This is fine, I can make 7 different scripts to access my 7 labels however it would be nicer if I could select the label on demand.
Any thoughts?
jeff
The script displays the group selector, sets the variable “theLocation” but you don’t use it afterwards. E.g. replace “in incoming group” with theLocation after adding this parameter to importMessage.
Hi Christian,
Thanks for pointing that out. I’m still just learning applescript and missed that little detail. Script works like a charm. Now, is there a way to bring up a selector for the label or do I need a separate script for each label?
j.
You could use the standard “choose from list” command to select a label.
