Basically what the title says. I’ve found this hidden preference in the documentation and was eager to use it but running
defaults write com.devon-technologies.think WindowToolbarStyleExpanded -bool TRUE
Did not change anything.
Thanks
Thanks
First off, it doesn’t change the state of open windows. It will show the change after opening new windows.
Secondly, if you’re running macOS Tahoe, change made by Apple disallow this from working on main windows. I will clarify this in the documentation for the next release.
Ok, thanks!
You’re welcome ![]()
