Hi everyone,
I’m triying to Drag & drop my system disk to locations but I can’t do…
You should not drop entire hard drives into DEVONsphere. You should add narrower, more focused locations.
Ok and why I can drop my second disk HDD, is because it’s not the system disk?
That’s right. The system disk contains too much bloat.
Ok thanks cgrunenberg. I’m not saving any relevant information in my SSD so I only use it to store the apps and the VMware machines wich I work so I’m going to disable it from searching and enable only the HHD wich is stored all hot data.
