I switched to iCloud and it works even better than Dropbox and much better than local sync I used at first
That’s interesting. I wonder if there were some way of gathering metrics on the reliability, in some sense, of different syncing methods, in terms of speed, likelihood of collisions/conflicts, etc. Not sure how such dependent measures would be captured, but it would certainly be interesting; at the moment it tends to be just anecdotal. Does anybody do this?
There are no metrics on reliablity for any remote sync method and results would be largely anecdotal anyways.
when you say that you can sync via bonjour when your ios device is plugged into to your computer via lightning cable - is that faster than syncing via bonjour without your phone being plugged in?
We have no metrics on this, but yes it should be based on the same logic of why Ethernet is far superior to WiFi, regarding stability and throughput.
Thanks!
