On the right hand side I have ‘shot’ the items selected for the columns. But ‘SOAF’ is not showing on the preview. When I deselect ‘SOAF’ and select again, not only does it not make any difference but also ‘Timetable 2 despatch’ is removed from the preview. When I deselect ‘Timetable 2 despatch’ then reselect it appears on the preview and so does ‘SOAF’ but ‘SOAF’ is still not on the preview.
Incidentally, regarding ‘Size’ column showing when not selected, I have found that clearing all still shows ‘Size’ on the preview.
Yes it does.
Also, when I select SOAF it’s not shown on the preview, Timetable 2 despatch is shown instead. I have checked the c/m and the respective Identifiers are the same as the c/m names.
I have just created SOAF1 and soaf2 in case there is a bug in the first. When adding either to the column view in the database inbox they show but when I select a folder they are gone and when I go back to inbox not in that view either. (Workspace comment deleted*)
Is it possible there is a limit on the number of columns?
posted too soon. After updating the saved workspace, quitting DT3 and open again and select the same workspace, the SOAF1 and soaf2 columns, together with Timetable 2 despatch have all disappeared from view.
