DTTG >Settings>Locations Dropbox>xxxfolder>(A) my databases
When syncing and I view (A) the only indication of progress is next to the Global Inbox. Is that as it should be or should there be a progress indicator next to each each database?
The progress indiciator will appear next to the database that is actually syncing. It’s not going to sync all of them at once.
Noted, thank you.
You’re welcome
