The issue is not to save a search. How do I edit the search that I saved?
Thank you. I know, I can Open With… I am doing that. But after a while, becomes boring to do it that way.
Smart groups can be edited byControl-click > Edit on them.
I see. Thank you. So a “Save Search:” becomes a Smart Group…
Should not be easier to write on the dialog “Save search as a smart group…” rather than “Save search:”?
If you had not told me this I would have thought it wasn’t possible to edit the search.
The suggestion is noted.
That is precisely what indexing does.
You can create a shortcut using macOS or a third party software like Keyboard Maestro.
