Thanks for your help, can you help me with some other Image Capture problems?
#Rename Unnamed Binder
If i create Unnamed Binder and rename the Unnamed Binder, in the sidebar the refresh don’t work and don’t show the new Unnamed Binder name
#Move documents
In the collectionview: Items will be copyed after drag and dop on a Unnamed Binder and not moved.
In the sidebar: Items will be moved after drag and drop.
Is it wanted like that?
#Issue with Unnamed Binder
I scan two documents, then i create the first Unnamed Binder.
I drag and drop the two documents on the sidebar on the Unnamed Binder.
(I noticed that the two documents do not belong together and have to be saved as individual pdf files)
I go into the first Unnamed Binder and then i put one document with drag and drop on the sidebar back to “Imports”
I open Imports and create a second Unnamed Binder for the second document.
After the second Unnamed Binder creation my document will not be displayed anymore. The documents pdf files are still there at /user/Pictures/DEVONthink 3/Scans
#Scan new document to "Create new Binder"
if i scan a document with following options
Name “”
To “Create new Binder”
Destination: “Inbox”
Kind “PDF”
Tags “”
OCR “enable”
Then i scan a document with the same options
Name “”
Kind “PDF”
Tags “”
OCR “enable”
A save button appears below the ocr button, if i press the save button.
The document will be saved as a pdf with two pages and moved two trash.
The documents at “/user/Pictures/DEVONthink 3/Scans” was not deleted.
The Binder will be removed from the sidebar, but it is sill displayed in the collectionview at the Imports.
It is not possible to open the Binder but you can delete the binder
#Sort and Merge Documents
I scan some documents and create three Unnamed Binder
I put in every Unnamed Binder, some documents
I open a Unnamed Binder and i get the option “Sort and Merge Documents”
If i select the first Unnamed Binder at Starting Odd Page and then i select the second Unnamed Binder at Starting Even Page, the selection at Starting Odd Page will be deleted and and I have to choose it again
(vice versa, it behaves the same way)
If the Starting Odd Page selection empty and the Starting Even Document is “Select Document”
If i select the first Unnamed Binder at Starting Odd Page and then i select the first Unnamed Binder at Starting Even Page, the selection is exchanged
(vice versa, it behaves the same way. I think that is so wanted)
If i select the second Unnamed Binder at Starting Odd Page and then i select the second Unnamed Binder at Starting Even Page, the selection at Starting Odd Page will be deleted
